Hi,
I have had a problem with my phone that drives me crazy since some time I installed little application called 'lock screen 7'. I really liked the way of unlocking (it's the simplest and fastest in my opinion - I touch the screen with my thumb and slide it up. works way better and easier than sliding to the right, especially with one hand) but there is some kind problem here. When I lock my phone, I usually get the original lock screen first, and after that the second, lockscreen7 one. It sometimes happens sometimes not.
Anyone knows if this is the 'LS7' application problem, or anything else in my phone? I tried with this 'no lock' application, that author mentioned in the description, but even when using it, results are the same.
Or maybe You know any other app that works in the same way?
I have also launcher pro installed, but don't think it has sthg to do with this.
any suggestions?
any suggestions?
