Help Two newb questions: Vibrant
vicj
Hello Everyone!
Two questions that are probably relatively simple for you experts, but mystifying to me, on my Samsung Vibrant:
1. If I downloaded an Application, such as Fennek Browser, used it for a while then deleted it, I noticed while running a virus scan that the installation files and such remain on the SD card. How can I access the SD card to delete them? I can't figure out how.
2. Has anyone used kik messenger on this board? I LOVE the app, but man it sucks power like a battery vampire! The question is, if anyone else is using it, is there a way in the android version to DELETE threads or messages? If there is, I can't find it. I've tried kik support, but no one there seems to pick up my messages.
TIA
-V
hi there!
cant answer no2 as i dont use the app im afraid,
as for navigating to the correct folder in the SD card to delete them, in the menu there should be a folder icon named 'My Files' find it in there!
