two questions regarding galaxy ace
Hi
1.)i have samsung galaxy ace mobile.But when i was downloading new application it always says memoryfull.How Can i move phone only applications to memory card?
2.)Can i update my galaxy ace to anroid 4.0?If it yes how can i do it?
Hi
Think it depends on the version of Android. If it's got 2.1 then no. With 2.2 and 2.3, I believe you can install apps on the SD-card.
No ICS 4.0 for the Ace sorry, as it doesn't meet the minimum specs required to run ICS.
when going into settings - applications - *app name* there should be an option to move to sd
