Help two questions
jrseriel
My phones dockbar does not go away when you change home screens. It just puts the other dock tab over it. Is this normal. And what is the difference between a factory reset and a clear all cache
Try powercycling your phone first (power off, then on), before resorting to clearing caches and Factory Resets.
No, but why not start simple first? A lot easier to powercycle than to have to setup all your homescreens following a Factory Data Reset. That's just me though. If you want to Factory reset your phone go right ahead. ;)
