ZMAX4EVER
There's a visual voicemail app pre-installed as part of the MetroPCS apps. There's also a visual voicemail option within the phone dialer app itself. When someone leaves a message, I think the two options are conflicting or the phone dialer app is overriding the metro app. Which app should I use? Should I disable the metropcs visual voicemail app or change the settings within the dialer?
Any ideas on keeping only ONE visual voicemail option?
