InertStatic
I have been doing reading and figuring out what kind of rom i want to install on my awe. What is the 2 programs ? Don't they both serve the same function ?
In laymans terms yes... Cwm is a little buggy it formats when it feels like it... Twrp has more options and is a touch interface... What roms were u looking at???I have been doing reading and figuring out what kind of rom i want to install on my awe. What is the 2 programs ? Don't they both serve the same function ?
Definitely need to use twrp as those roms use newer script syntax... Just b warned that they have some issues still... If u dont mind a 4.1.2 rom i have both a kk themed and "L" themed rom availableSlimkat or carbon. They seem to be the most stable.
flashing is easy just follow the instructions u b fine brittnearl and others here will help u there is a great bunch of people in this forum
Don't overclock this phone . It doesn't like it . I know of 2 people who had problems with this phone after they overclocked . They had to trash their phone because of stutter issues .
I personally like T.W.R.P. version 2.7.1.0 and L awe version 2.0 . Stable , great battery life , plenty of features and everything just works . You can use the L awe stock version which installs recovery , root and the ROM all at once . Once you do that , you can then install TWRP easily . All the other ROMs have issues like Bluetooth not working or camera issues . I'd go with L awe or even Moonshine . Just follow the instructions and you'll do fine . Good luck and let us know your results .
Ur saying the stutter issue occurred after reverting back to stock kernel???Don't overclock this phone . It doesn't like it . I know of 2 people who had problems with this phone after they overclocked . They had to trash their phone because of stutter issues .
My son for instance had to trash his phone after he overclocked his awe because of stuttering even after he went back to stock ROM . He went out and bought another one and problem solved . The problem was a hardware failure . Apparently his phone heated once too much and he damaged his processor . It burned out some of the transistors . It happened to another friend of mine also . This phone does not like to be overclocked . It's an inexpensive device and the way the chips were installed gives very little forgiveness for overvolting and has no cooling whatsoever . It was made in the cheapest way possible . Not saying it's a bad phone especially in it's price range , just saying to be cautious .Ur saying the stutter issue occurred after reverting back to stock kernel???
I run both cores 1.7 or 1.9 no problems but if ur running it on a game then it will heat up I tryed an idea seams to b running cool but some people didn't ageree with it but worked for me I even got my phone in an hard case with stand I keep mine wide open 24 -7 I just got one of the good ones I geuse
Is there any way to tell which processor you get ?
Only thing that would cause a overheat to the point hardware failure would b incorrect thermald control or it being totally disabled which is y i made the stock kernel flashable to add these bk as spock removed external thermald and made it kernel sideMy son for instance had to trash his phone after he overclocked his awe because of stuttering even after he went back to stock ROM . He went out and bought another one and problem solved . The problem was a hardware failure . Apparently his phone heated once too much and he damaged his processor . It burned out some of the transistors . It happened to another friend of mine also . This phone does not like to be overclocked . It's an inexpensive device and the way the chips were installed gives very little forgiveness for overvolting and has no cooling whatsoever . It was made in the cheapest way possible . Not saying it's a bad phone especially in it's price range , just saying to be cautious .
The Dev sets how the device adapts to heat. It's up to you to decide how high to go. We make your transmission better, its up to you not to tear it upTranslation ?
Agreed its a little buggy when booting into recovery eg: sometimes reboots instead of going to recovery... Once in all is well... If u still have issues reflash the recoverytry removing bat and charger. then re insert then try to boot again some times it works
