Typing while charging Problem
RD07
I don't know guyes that this happens with you all or its some kind of defect in my phone only.!!
when i connect my phone with a charger and start typing a message all goes well ..
but sometimes when i long click at any key, some random keys get automatically pressed.
So what is this issue?? Is this with every android phone ?? Is it a manufacture defect ??
or its just faced by me.!!
and as mentioned above it happens only sometimes ....
so if you guyes gonna try this then plz check thoroughly .!!
I had faced similar problem (not same) while charging phone.I was using local charger.
but when I used the original one, all went off.
Are U using other charger.
If yes ,then u should use original charger and Usb cable.
Thanks.
yaa me too faced this problem when I used vivaz charger
but there wont be any problem if u use original charger provided by micromax
well i use the original charger only.!!
given by mmx .!! it came within the box.!! but still has that defect.!!
i don't know whats happening??
i am also facing same problem ,but might it is due to earthing problem .....
