Udroidx 01.05.07 beta
lucsp
UDROIDX 01.05.07 BETA
Flash Player 11 ready, Improved WIFi- Sound-Battery-New Launcher 360
Built on the 1.5.7 firmware WM8650 ;
Based on HCH v12 and Midervadroid ROMS, Thanks to DIABETU.
010507UDROIDX.7z - 4shared.com - online file sharing and storage - download
To install :
Format a SD card to FAT32
Extract the contents of the zip file to your SD card.
Choose your env.uboot file under Firmwareinstaller/env according your device and rename env_uboot .
insert SD card into your device and power on ; upgrade will run automatically. Once it​
