UK: How can Carphone Warehouse sell the M9 cheaper than direct from network?
Alex_NJ
I'm waiting to pre-order the M9 and comparing pre-order prices. (I hope this doesn't look spammy and get deleted by mods)
Carphone Warehouse upgrade EE offer with Free case.
EE's own upgrade offer
Am I missing something, how can Carphone Warehouse offer it so much cheaper?
The iPhone 6 is also significantly cheaper through Carphone Warehouse
Thanks!
Both will be 24 month contracts.
So direct from EE would be: £1267.75
From Carphone Warehouse it would be: £1007.76 (plus a free official Dot View case which I guess is worth £20)
Because CPW are trying to attract business, while EE assume upgraders will upgrade directly with them?
There's another advantage to going with CPW: unless they've changed their policy recently they use unlocked, unbranded handsets, whereas if you upgrade through EE you'll get a locked handset with EE-modified software - which means you wait longer for updates because they have to wait for EE to finish fiddling with them rather than coming straight from HTC.
Wow, that is a point that I had completely overlooked.
Especially good if I want to buy a SIM for going abroad too.
Thanks!
A combination of brains and brawn. :)
They negotiate exclusive packages with the networks, and have huge purchasing muscle with the manufacturers.
Nope, still the same. Network-locked handsets tie you (and your stock) to that particular network.
