UK Water Damage Indicator Colours?
Renniks
Hi All
I have searched the web for the answer but have found mixed answers. My water damage indicator when you take the battery out is white with pink X's to my knowledge no water has got in but I have all of a sudden lost signal to my mobile network.
Could it be the antenna?
Thanks
Renniks
The water indicators are fine. If water had gotten in the red X would bleed onto the white. As far as signal it could be problems with the towers of your provider. I would turn off the phone and pull the battery for about 30 seconds. Put battery back and restart the phone. If this does not help you should contact your provider to see if there is an outage.
Thanks for the Info Mate. At least I know it ain't water. I am being told it could be blacklisted. Frustrated ain't the Word! Just stopped working all of a sudden bizarre.
