Root UltaLolli ROM for LG Ultimate 2
Ok, I found the problem. I had to go into Heads-up notifications/settings/App filters/ and uncheck Xposed Installer and now the downloads show up.
Does heads up still work, I also flashed the lg camera, on first boot it says optimizing apps and android is upgrading that's normal,
Pngs... so is incall ui havent had time to mess with stuff lol ur more than welcome to contribute if u like :)
So much of our roms images are now vectors...its a pia to relearn everything lol. Yeah I'm off Thursday and Friday if you want to shoot me a link to the apks I don't mind lending a hand. :)
Will do man :) i have a dev device i was hoping a source rom builder would find interest in the device
When I tried to flash, I'm getting 'error executing updater binary'.
I booted into twrp v2 recovery. Went to WIPE. I performed a factory reset and then Advanced and wiped system. I then tried installing the ROM and it gave me that error. So I restored my backup successfully. I always verify the md5 of my d/l and it checked out. I redownloaded the ROM and get the same error when installing.
Go into mounts and uncheck system. Then flash again ;)
Hmm. When I went to mounts, system is already unchecked.
EDIT: In mounts, I tried checking system and re-unchecking system. Installing ROM still produces the error executing updater binary.
Try wiping data, dalvik cache, and cache, then from twrp menu reboot to recovery, then try flashing again.
Hey how do I get rid of the little "QSLIDE APPS" thing in the status bar? This rom is really REALLY nice its just that one thing that really gets annoying, and i cant figure out how to remove it
Ok. That allowed it to flash the rom. Problem now is for some reason there is no keyboard, voice comes up but is not functional. I assume this is a dirty install? I was able to get into twrp from power off and did a factory reset. Same problem. Am I wiping the data correct? You tap WIPE and then swipe for factory reset?
No I had the same issue. You have to go to settings,input, and check google keyboard
