Root Ultimate Droid 2.1 ERE25 ROM vs Simply Stunning 2.1 ERE25 ROM?
huytung
Member
has anyone play with both ROM yet to see which one is better? or any comment you guys think which one would be better? or which one would you choose to go for? or am i going to get "try both and see what fits you" answer
well for me, the stability of SS is better, i nandroided to ultimate 3.7, then update.zip to 4.0 and did an update.zip to 2.1 better version and it force closed a TON! mostly the launcher stuff, pretty unbearable... i dunno what a nandroided version of its like. but with the launcher, probably not good.
so SS has been stable, it has patches to fix the minor bugs, its not bad
Wonder if the FCs were due to using Update? I see he removed the update.zip and just has a nandroid..
What do some of the screens for SS Look like?
they are blue haha. a lot of blue :) its nice, 5 screens. sounds like everything works, i haven't tested it all, but i have not had one FC since i patched it
the blue smaller home beautiful widgets is my own doing
I used Ultimate and it was ok. Seemed slightly buggy to me, so I ditched it. I'm using DroidMod right now (never used it before!).
Haven't tried SS. Worth trying over DroidMod? I'm thinking of sticking to DroidMod till Pete gets a solid 2.1 rom out. v.5 didn't tickle my pickle.
What is the name of the app that allows you to have that many homescreen icons again?
SS has been better for me, once I got it running. Had some boot loop problems that I couldn't figure out which randomly fixed themselves when I re-restored the nandroid backup. Now that it's fully up and running, it's the smoothest ROM I've used so far, running very fast and cool. I am not too fond of some of the design choices in the theme, which I may mix and match, but overall it's one of the better ones I've used so far.
