bryanberlin
Once again Joseph Mother Cudos
Transform Ultimate Kernel Package
Incredible work, thought id share this with A.F.
I was working with my wifes Transform and am using this Kernel on
http://forum.sdx-developers.com/tra...-2-eb28/?PHPSESSID=4354sjvp92gnaidua2rd2n3vr7
Ubuntdriod ROM
AWSOME COMBO thanks to the developers for thier great work and making our phones better by leaps and bounds!!!!!!!!!
Here is a quick flash to give any rom, even stock, everything you need for the fastest setup on your phone. It includes:
Build.prop tweaks for speed and battery life
Samdroid's jit that is in UD
Minfreemanager to make it easy for you to keep enough memory free to keep jit happy
CrapKernel for the transform, which includes:
root
ext2/4 support
busybox
wifi tethering support
tcp window increased for faster data
read ahead changed for faster sd card speeds
sleepers disabled
133mhz removed
stepping table changed so the phone will wake up fast
samdroid nand read/write tweaks
userspace governor
deadline scheduler
usb draw increased for faster charging from your pc
virtual screen disabled
parallel port support removed
branch prediction enabled
optimized for the s3c6410
Ubuntdriod ROM
root
ext2/4 support
busybox
sleepers disabled
133mhz removed
userspace governor
deadline scheduler
