umm.. optical joystick..
alexfl98
uhh.. im sorry if that is wrong section but this UI confused me a little
today i downloaded like 5 or 7 rpgs (offline mode) and all had screen joystick and.. all .. failed to launch.. after i start them create char etc and start to play , my screen goes black and app crash , one last longer and i noticed that its happening because of screen joystic( when i touched it the game crashed)
my phone is alcatel ot 918 (orange).
today i downloaded like 5 or 7 rpgs (offline mode) and all had optical joystick and.. all .. failed to launch.. after i start them create char etc and start to play , my screen goes black and app crash , one last longer and i noticed that its happening because of optical joystic (when i touched it the game crashed)
I'm assuming you mean on screen joystick?
I had a quick search on your phone and it's quite under-powered by today's standards from what I can see. (650mhz processor and 256mb RAM, and seems as standard it only has 150mb of free space on the phone which might be effecting it).
Can you tell me what games you are trying to play? And are you running them though an emulator or they are just games off the play store? If I know that I can tell you whether you phone is just too outdated internals wise, or I can see if I can twig what the issue is. Can you also tell me how much free space is on the phone memory?
e.g. zenonia 5 crash , but zenonia 4 (which dont got a previous version of screen joystick)don't even lag with best visual effects.i download games and apps from pc then send it to phone through bluetooth or usb cable,i have left 1.3gb hdd space and 120 ram usually like 70-90 free
sorry for confusing "optical" with "screen"
o.o i found a game called Third Blade ,it have screen joystick and it wont crash even at full ghrapics
OK going on that id have to say its just down to specific games then. Most likely some of your games wont work on you phone due to the age of the internals.
You could always try using a task manager to kill everything but the game before you launch it but i'm not sure how effective this will be.
Technically the processor and graphics chip in your phone (Qualcomm MSM7227 with adreno 200 graphics) has been around in some form since 2008 so its getting on a bit, and I'm not surprised some of the games are crashing tbh. Plus having only 256mb of RAM to play with in the phone is not going to help.
The only thing i can suggest is to maybe root the device, apply a custom rom that pure stock android and maybe overclock the processor. you should be able to clock it up to 800mhz from 650mhz with no trouble as thats what the processor is rated to anyway.
The folks over at http://forum.xda-developers.com can probably help you out with this, if you decide to give this a go (i have no clue about rooting so I can't help i'm afraid), just back everything up before you do if you decide to do this.
Personally I would just shell out for a less outdated phone though. Would be better in the long run for you.
