I am unable to connect My Moto Droid to the public WiFi at the hospital I work at. I can connect fine at home to my netgear A/P.
I can connect fine at work with my laptop or iPod touch.
I am able to get an IP address and it appears to try to connect to the login/acknowledgement page but fails with a data connectivity problem: the connection to the server was unsuccessful. It appears to be failing at the redirect at about the same time the iPod touch asks to accept an invalid (likely self-signed?) certificate. I have verified otherwise that I can connect to a page with an invalid certificate.
My droid is rooted and busybox is installed if anyone has ideas on things to test.
This is a cisco wlc I am trying to connect to. From what I have read, this is how the connection happens
1.Connect get ip address
2. When http command received, rediect to acknowledgement page.
3. User accepts acknowledgement and then wlc allows device to connect to net
it is failing somewhere in step 2. It does redirect to http://1.1.1.1/login.HTML but it won't load the Acknowledgement page with the invalid cert.
