Help Unable to connect to WiFi network
gavinjb
Hi,
I have just got an HTC Wildfire, but unfortunately I am having problems connection it to my home Wifi network.
I am connection to a EDIMAX BR6574n Router and I have the follwoing configured
SSID Visible
WPA2 AES Passphrase Encryption
Wireless Access control (limits devices by MAC address) have disbaled until I can get connected
I have even reset my passprase incase I have forogtten it (unlikely).
The problem I get is when I try to connect I see the Wifi in the corner of the screen briefly with full bars, but it has a ! next to it and then it disconnects.
Can anyone help.
Thanks,
Gavin,
Found the problem, I had forgotten that I had limited my Router to N class routers, I have updated it to broadcast at b/g/n and I now am connecting fine.
