Unable to make call from my real device
ianni
Hello everybody.I want some advice,i make a program on Android and i wanto to do this,i want to run the app on my real device wich is attach on Android Studio,show my contact list,and when i push a number to start calling.
This is my code
Java:
public class MainActivity extends AppCompatActivity {
    public static final int PICK_CONTACT_REQUEST = 1;
    TextView contactNumber;
    @Override
        setContentView(R.layout.activity_main);
        contactNumber = (TextView) findViewById(R.id.contactnumber);
        Button buttonPickContact = (Button) findViewById(R.id.pickcontact);
        buttonPickContact.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View view) {
                pickContact();
    private void pickContact() {
        Intent pickContactIntent = new Intent(Intent.ACTION_PICK, Uri.parse("content://contacts"));
        pickContactIntent.setType(ContactsContract.CommonDataKinds.Phone.CONTENT_TYPE);
        startActivityForResult(pickContactIntent, PICK_CONTACT_REQUEST);
    protected void onActivityResult(int requestCode, int resultCode, Intent data)
        if (requestCode == PICK_CONTACT_REQUEST) {
            if (resultCode == RESULT_OK) {
                Uri contactUri = data.getData();
                String[] projection = {ContactsContract.CommonDataKinds.Phone.NUMBER};
                Cursor cursor = getContentResolver()
                        .query(contactUri, projection, null, null, null);
                cursor.moveToFirst();
                int column = cursor.getColumnIndex(ContactsContract.CommonDataKinds.Phone.NUMBER);
                String number = cursor.getString(column);
               //HERE IS THE PROBLEM,WHEN I HIT A NUMBER IT RETURNS TO THE STARTING SCREEN
              //I TRY TO DO WITH INTENTS
              Intent intent = new Intent(Intent.ACTION_CALL,Uri.parse(number));
             if (ActivityCompat.checkSelfPermission(this, Manifest.permission.CALL_PHONE) !=                          PackageManager.PERMISSION_GRANTED) {
    // TODO: Consider calling
    //    ActivityCompat#requestPermissions
    // here to request the missing permissions, and then overriding
    //   public void onRequestPermissionsResult(int requestCode, String[] permissions,
    //                                          int[] grantResults)
    // to handle the case where the user grants the permission. See the documentation
    // for ActivityCompat#requestPermissions for more details.
startActivity(intent);
Thank you very much for any sugestions
