Unable to modify calendar in S Planner
joemonkey
when i select an event from S Planner, i see it belongs to calendar, saying lunch. but when i edit the event, the calendar section is all grey out, thus i am unable to change the change from lunch to another calendar.
is this a bug with S Planner??
however, when i open the same event with another calendar app (calengoo), when i edit the same event, i can change the lunch calendar to something else.
wow, no one has the same issue as me?
also, when i create a task, say for sep20, in the agenda view, it shows up under sep21 (NOT sep20). this is very odd that it does not show up in sep20, but in sep21 instead. surely this got to be a bug. can anyone please test and verify this?
i am running ICS
i am running ICS
I have the same issue with not being able to change the calendar of an event but not your task issue.
MY CALENDER seems to be the default when I use VOICE COMMAND (which is what I mostly use) Does anyone know where can I find the settings to have a NOTIFICATION alert be made automatically for MY CALENDER when I make a new event from VOICE COMMAND?
Thanks, jeff
