Help Unable to read Malayalam language font in Android
Hi All,
I am unable to see malayalam fonts in Websites or in gmail. How to fix this font problem? I am using Samsung Galaxy Ace S5830, Android 2.2.1
Thanks in advance
Hi I'm also looking for the same feature for my moto cliq xt. Preethiraj, if you found any solutions, pls post it here if you don't mind.
Thanks in advance - Dibu
Install Opera Brouser first.This will work for almost all language which has unicode character maps available. eg:- Indian languages Malayalam, Hindi, Kannada, Telugu, Punjabi, Gujarati, Bengali etc.
Inorder to read, we have to enable a special menu on the Opera Mini browser by typeing "about:config" in the address bar of Opera Mini and click "Go".
This will open a configuration menu as shown in the screen shot below. Here we will be able to change lot of settings like feedindex, linklists folding etc. In ths menu there will be an entry called "Use bitmap fonts for complex scripts". By default this setting will be disabled. Now change the setting to Yes and click Save.
Scroll down to find the option "Use bitmap fonts for complex scripts"
Change setting to Yes
Usually while processing a web page for mobile phones in opera mini servers, text will be sent as normal text and font information. So the actual rendering of the font happens in the mobile. This method causes comparitively less bandwidth. After the change in the setting, Opera Mini server will render the text at server itself, then convert it to bitmap images and then send to phone. So the phone will display correct text.
This method works for other languages other than Malayalam also.So have good time reading an article in your local language using mobile while you are on move.
Note: Enabling this option will result in higher data rate. For example, yahoo malayalam site size is 91KB with setting and it was only 28KB before enabling the setting.
If you are upgrading Opera mini to a higher version, then this setting has to be done again.
Best Wishes...
Hi All,
Thanks in advance
Download FONT FOR GALAXY SP (free) and follow the instructions.
Good luck
regards
ABYCHAN KOKKATTU ALEX
