Unable to remove screen lock
pnb
Hi,
I have recently bought a second hand S3 and whilst waiting for a case I put a code screen lock on in Settings. Now I have the case I want to remove it but the option has gone from Settings ???
What do I have to do to remove it?
Thanks
Set the lockscreen to "none" (or whatever you want other than a code - you can use PIN, password, pattern or swipe).
Settings/Device/Lock screen/Screen lock. You'll have to enter the code you put in to be able to change the lock method.
Thanks
It isn't under the Devices section. I thought I had set it up under Security or Screen, but screen lock is not there!
On further investigation there is a a Lock Screen section under Settings>Personal. I think there must have been some changes with the recent updates?
Cheers
