Help unable to scan for networks
Last night I downloaded updates with LG Mobile Update. It changed my OS to 2.6. Now my WiFI isn't working. When it scans a message that says
prior to doing this the phone got on my home wireless network fine.
Can anyone help?
thanks
Strange I just plugged mine. it say it needed an update but after doing it it remain 1.6 version 10Q.
Did you resolve the no wifi issue?
I'm have the same problem and will try a factory reset after disabling the wifi as it may correct the issue.
Android version 2.2
Software v20d
Factory reset worked for me.
Try a factory reset, you will lose you installed apps, contacts and other settings in your phone. The SD card will not be reset or lose information.
Using LG EVE GW620 Android version 2.2 Firmware v20d
