Help Unable to send MMS
hArLtRoN
I have a rooted Sprint S3 running the Wicked S5 Xperiencev1.0 ROM and I'm having issues sending MMS.
For about two years I had Google Voice and my Sprint number linked together because my school had horrible reception and WiFi everywhere.
Well I've now removed my Sprint # from Google Voice completely and I cannot send MMS messages now.
I did try going from 4G to 3G and it sent ONE MMS but it wouldn't send another.
Any ideas?
Thanks,
hArLtRoN
So I downloaded a 3rd party SMS app (Textra) and now I can send pictures. Seems to be an issue with the stock messaging app
So you're saying after you flashed v5.0 the MMS issue fixed itself?
Im on the wicked sensations v50 and don't have really any issues im using the galaxy s3 Model# L710 for boostmobile/sprint
I absolutely love this rom I wouldn't change it for anything else although there is a few other roms I like this one I feel hits me the best. how can you not like the # keyboard feature makes this things so much faster bam pow done ... lmao. there is alot of other features on here to. it just gives you a good clean feel and look to it.. It also saves you alot of internal space for storage im using maybe 3gigs with all of my apps included with the rom itself installed and still have about 10gigs left before needing to touch my external storage. battery life seems to be rather well on this rom to..
and the good part is Boosts #*____'s work on this rom as well and the prl and profile updates works with it
so if any problems you can go in and fix it ota... bling!!! solved
Could you post a link to the v5.0 ROM? I aldo have the Sprint S3 (L710)
I'll try it out soon. As for now a 3rd party SMS app is allowing me to send MMS messages.
Also if u like the rom u have u could go to the main part of the forum and look in Samsung s3/boost mobile/boost mobile root/ look for the forum that wet biker started in the stickies .
roms modems ect there's a mms fix I think moped Ryder had made should be like 3-4 messages down the list
