Unboxing problems?
rootbrain
Did anyone have problems like in the comedy videos posted with unboxing the Nexus 7?
Took me all of 45 seconds. Only because I took my time, LOL. :D
I'm going to be prepared when I get mine...
I am not sure why people had so much issues opening the box, I was wondering if it would be difficult, no problems here. Opened it the same way I do every box, with a knife.
Where the videos had trouble was after cutting through the tape and separating the two sides of the box.
For me, it was a non-issue. I cut the tape, held the top half of the box and the the bottom half slid out with no problems. Easy peasy.
Mine was easy as well and I didn't even use a knife. Just my house key.
Maybe it is an intelligence test?
If you can't open it you aren't qualified to use/own it.
That's why I'M using a chain saw!
sliding it out of the sleeve was the hardest part for me. it was on there VERY tight. i almost had to resort to tearing it off.
sliding the boxes apart was a breeze.
