Root Unbrick/Unroot Stock Lollipop 5.0.1 firmware
su_me
Can we get a moderator to stickie this to the all things root guide for revision purposes please?
http://forum.xda-developers.com/galaxy-s4-att/general/guide-odin-to-stock-updating-rooting-t2926642
Found this after soft bricking my S4 because I got too impatient and didn't want to read like I know I should and flashed TWRP recovery with a locked bootloader smh.... But I did however get it working with this so hope it helps others. Also, you can downgrade back to 4.4.2 in case you want to.
Thanks alot and keep playing with tech, it's fun!
Sorry, P.S. this link gives you the AT&T .tar files but a little research with your carrier's name should yield results. The method will still be the same.
