Help undelete a folder
ScttLee
I stupidly deleted a wrong folder from my SD card. Anyway to retrieve the folder? On the phone, or via a PC. No data has been added to the card since then.
Try Recuva. It's a Windows program Edit: I may have misunderstood. Ignore my post, Hadron is the man!
As long as it's a removable card that will work fine (if it doesn't work in the phone, which is actually quite likely, stick it in a USB card reader).
If by SD you mean /sdcard, the "internal SD" (i.e. part of internal storage emulating an SD card) you may be out of luck. Android uses MTP rather than USB Mass Storage to mount the storage on a computer, and file recovery won't work over MTP.
