Apps Understanding xml properties
mvmd
So I'm obviously new to developing for droid, as well as Java, and as I'm following along through tutorials I see in the xml for a textview for example:
HTML:
android:id="@+id/label"
What I'm wondering about, is there a specific reason there's a '+' infront of id?
The + is there to add the id to the auto generated R file. If you take the + away, you would have to manually go into the auto generated file(you hear it sounds bad) and add it yourself.
