alexbrown99
Guys
Can anyone help with this please? I got an S2 a few months ago from T-mobile and it was running on gingerbread, battery life was good, would last two days on standby if i didnt use it much. Then suddenly one day it started draining battery really quickly. I went away on holiday and took my phone with me and didnt have a charger so it turned itself off with zero battery for a few days. Came home, charged it up and it was still draining battery like nobodys business. I thought i'd try ande get to the bottom of it and i was removing apps, checking for viruses, turning data connections off etc. I have tried removing battery for 30 sec then putting back in, replacing battery with a brand new one, i have tried using diffrent charger, I even resorted to factory resetting the phone, it didnt work though. you name it and i've done it.
Eventually I upgraded the OS to ICS 4 via samsung kies as part of the ICS rollout, but battery was still being drained and I wasnt getting the 2 days I used to get on standby. I downloaded better battery stats to try and locate and understand the root cause of the battery drain. Below is the results, the phone is in deep sleep most of the time but still drains so much battery. have a look at the below stats, 35% battery drain in 6hrs 37 mins. is that normal? According to these stats battery would only last a total of 1134 mins or 18 hours. far from the 2 days i was previously getting.
Any ideas why it is doing this? Has anyone else got this problem?
General Information
BetterBatteryStats version: 1.9.2.2
Creation Date: 2012-08-08 13:17:00
Statistic Type: (3) Since Unplugged
Since 6 h 33 m 22 s
VERSION.RELEASE: 4.0.3
BRAND: samsung
DEVICE: GT-I9100
MANUFACTURER: samsung
MODEL: GT-I9100
OS.VERSION: 3.0.15-I9100BVLPD-CL364024
BOOTLOADER: unknown
HARDWARE: smdk4210
FINGERPRINT: samsung/GT-I9100/GT-I9100:4.0.3/IML74K/BVLPD:user/release-keys
TAGS: release-keys
USER: dpi
PRODUCT: GT-I9100
RADIO: I9100BVLPB
Rooted: false
Battery Info
Level lost [%]: 34
Voltage lost [mV]: 362
Other Usage
Deep Sleep (): 5 h 53 m 28 s (21208 s) Ratio: 89.9%
Awake (): 39 m 53 s (2393 s) Ratio: 10.1%
No Data Connection (): 33 m 22 s (2002 s) Ratio: 8.5%
No or Unknown Signal (): 33 m 22 s (2002 s) Ratio: 8.5%
Wifi On (): 32 m 35 s (1955 s) Ratio: 8.3%
Wifi Running (): 32 m 33 s (1953 s) Ratio: 8.3%
Screen On (): 14 m 33 s (873 s) Ratio: 3.7%
Good Signal (): 10 m 34 s (634 s) Ratio: 2.7%
Poor Signal (): 20 s (20 s) Ratio: 0.1%
Wakelocks
BackgroundRequestService (com.facebook.katana.Facebook): 2 m 26 s (146 s) Count:15 0.6%
RILJ (Phone): 1 m 32 s (92 s) Count:515 0.4%
FacebookService (com.facebook.katana.Facebook): 1 m 28 s (88 s) Count:9 0.4%
AlarmManager (Android System): 25 s (25 s) Count:562 0.1%
GTALK_ASYNC_CONN_alexbrown986@googlemail.com/androidc0e2550da099 (Google Services): 24 s (24 s) Count:28 0.1%
NetworkLocationLocator (Google Services): 20 s (20 s) Count:7 0.1%
ActivityManager-Launch (Android System): 20 s (20 s) Count:125 0.1%
GTALK_ASYNC_CONN_com.google.android.gsf.gtalkservi ce.AndroidEndpoint (Google Services): 18 s (18 s) Count:250 0.1%
sleep_broadcast (Android System): 15 s (15 s) Count:190 0.1%
DHCP (Android System): 8 s (8 s) Count:204 0.0%
fullsync (com.whatsapp.WhatsApp): 7 s (7 s) Count:1 0.0%
show keyguard (Android System): 6 s (6 s) Count:13 0.0%
StartingAlertService (com.android.mms.Messaging): 5 s (5 s) Count:13 0.0%
SyncLoopWakeLock (Android System): 5 s (5 s) Count:599 0.0%
Event Log Service (Google Services): 3 s (3 s) Count:20 0.0%
NetworkStats (Android System): 3 s (3 s) Count:67 0.0%
reset keyguard (Android System): 3 s (3 s) Count:221 0.0%
*backup* (Android System): 3 s (3 s) Count:227 0.0%
AudioOut_1 (1013): 2 s (2 s) Count:1 0.0%
GTALK_CONN (Google Services): 2 s (2 s) Count:229 0.0%
SCREEN_FROZEN (Android System): 2 s (2 s) Count:211 0.0%
SMSDispatcher (Phone): 2 s (2 s) Count:1 0.0%
ActivityManager-Sleep (Android System): 2 s (2 s) Count:587 0.0%
M (net.dinglisch.android.taskerm.Tasker): 1 s (1 s) Count:103 0.0%
ConnectivityService (Android System): 1 s (1 s) Count:563 0.0%
Kernel Wakelocks
secril_fd-interface (): 8 m 23 s (503 s) Cnt
c/wc/ec)203/0/0 2.1%
multipdp (): 7 m 12 s (432 s) Cnt
c/wc/ec)86/0/86 1.8%
PowerManagerService (): 6 m 27 s (387 s) Cnt
c/wc/ec)850/0/0 1.6%
l2_hsic (): 3 m 20 s (200 s) Cnt
c/wc/ec)896/0/0 0.8%
umts_ipc0 (): 3 m 7 s (187 s) Cnt
c/wc/ec)487/0/487 0.8%
sec-battery-monitor (): 2 m 32 s (152 s) Cnt
c/wc/ec)310/247/0 0.6%
radio-interface (): 2 m 19 s (139 s) Cnt
c/wc/ec)201/0/0 0.6%
deleted_wake_locks (): 2 m 3 s (123 s) Cnt
c/wc/ec)7759/0/177 0.5%
alarm_rtc (): 1 m 50 s (110 s) Cnt
c/wc/ec)212/0/31 0.2%
alarm (): 1 m 45 s (105 s) Cnt
c/wc/ec)386/3/0 0.4%
rpm_hsic (): 1 m 34 s (94 s) Cnt
c/wc/ec)594/0/0 0.4%
power-supply (): 2 s (2 s) Cnt
c/wc/ec)310/0/0 0.0%
KeyEvents (): 1 s (1 s) Cnt
c/wc/ec)4493/0/0 0.0%
secril_fmt-interface (): 1 s (1 s) Cnt
c/wc/ec)1963/0/0 0.0%
mmc2_detect (): (0 s) Cnt
c/wc/ec)1/0/1 0.0%
mmc1_detect (): (0 s) Cnt
c/wc/ec)370/0/0 0.0%
mmc0_detect (): (0 s) Cnt
c/wc/ec)370/0/1 0.0%
Alarms (requires root)
Network (requires root)
CPU States
1.2 GHz (): 0.0%
1 GHz (): 5 m 13 s 1.3%
800 MHz (): 2 m 55 s 0.7%
500 MHz (): 8 m 20 s 2.1%
200 MHz (): 23 m 35 s 6.0%
Deep Sleep (): 5 h 53 m 28 s 89.8%
Reference overview
Custom: Reference custom_ref created 2012-08-07 22:08:21 (Wl: null; KWl: null; NetS: null; Alrm: null; Proc: null; Oth: null; CPU: null)
Since charged: Reference since_unplugged_ref created 2012-08-08 06:43:27 (Wl: 1 elements; KWl: 18elements; NetS: 0 elements; Alrm: 1 elements; Proc: null; Oth: 6 elements; CPU: 6 elements)
Since screen off: Reference since_screen_off created 2012-08-07 22:08:21 (Wl: null; KWl: null; NetS: null; Alrm: null; Proc: null; Oth: null; CPU: null)
Since unplugged: Reference since_unplugged_ref created 2012-08-08 06:43:27 (Wl: 1 elements; KWl: 18elements; NetS: 0 elements; Alrm: 1 elements; Proc: null; Oth: 6 elements; CPU: 6 elements)
update: phone is now on 35% battery (65% depleted) after 11 hrs 10 mins. Hardly used it. WTF!
General Information
Since 6 h 33 m 22 s
BRAND: samsung
DEVICE: GT-I9100
MODEL: GT-I9100
BOOTLOADER: unknown
HARDWARE: smdk4210
TAGS: release-keys
USER: dpi
PRODUCT: GT-I9100
RADIO: I9100BVLPB
Rooted: false
Battery Info
Level lost [%]: 34
Other Usage
Wakelocks
Kernel Wakelocks
c/wc/ec)203/0/0 2.1%multipdp (): 7 m 12 s (432 s) Cnt
c/wc/ec)86/0/86 1.8%PowerManagerService (): 6 m 27 s (387 s) Cnt
c/wc/ec)850/0/0 1.6%l2_hsic (): 3 m 20 s (200 s) Cnt
c/wc/ec)896/0/0 0.8%umts_ipc0 (): 3 m 7 s (187 s) Cnt
c/wc/ec)487/0/487 0.8%sec-battery-monitor (): 2 m 32 s (152 s) Cnt
c/wc/ec)310/247/0 0.6%radio-interface (): 2 m 19 s (139 s) Cnt
c/wc/ec)201/0/0 0.6%deleted_wake_locks (): 2 m 3 s (123 s) Cnt
c/wc/ec)7759/0/177 0.5%alarm_rtc (): 1 m 50 s (110 s) Cnt
c/wc/ec)212/0/31 0.2%alarm (): 1 m 45 s (105 s) Cnt
c/wc/ec)386/3/0 0.4%rpm_hsic (): 1 m 34 s (94 s) Cnt
c/wc/ec)594/0/0 0.4%power-supply (): 2 s (2 s) Cnt
c/wc/ec)310/0/0 0.0%KeyEvents (): 1 s (1 s) Cnt
c/wc/ec)4493/0/0 0.0%secril_fmt-interface (): 1 s (1 s) Cnt
c/wc/ec)1963/0/0 0.0%mmc2_detect (): (0 s) Cnt
c/wc/ec)1/0/1 0.0%mmc1_detect (): (0 s) Cnt
c/wc/ec)370/0/0 0.0%mmc0_detect (): (0 s) Cnt
c/wc/ec)370/0/1 0.0%======================
CPU States
1.2 GHz (): 0.0%
Reference overview
