Good day folks,
Issue:
I've noticed System_Server and a few other items (below) severely draining the battery on my Galaxy S5 (3-4% per hour, when it's normally .75%/hour). In the past few weeks (*usually* worse when I'm at the office), the top Kernel Wakelocks and "Process" wake time (reported by BBS) have been:
As far as I can tell, this did not start as of newly installed software, but it could certainly be due to an update to an existing program. Whatever the cause, though, I need to find out, because a dead phone is useless
Issue:
- Ipc00000016_Time_Daemon (which I can't find ANY info about, even when just Googling “time_daemon”)
- WakelockManagerTimeout (likewise - no useful info, literally only SIX (6) results on Google).
- System_Server (nothing concrete when Googling besides "try Wakelock Detector")
- "IPC_###_Event0"/ “event0-###” every now and then, where ### is a Process ID. When I check the PID via Terminal (Cat /proc/*PID*/cmdline) the PID ends up belonging to "System_Server".
- Numerous EventXX-### records, where XX is an event number and ### is a Process ID (usually the same PID tied to Event0 as noted above).
- Numerous Kworkers
- To make a Windows comparison, it looks like System_Server is "RunDLL32" or "SVCHost", wherein, numerous processes can "hook" into "System_Server" and are thus disguised behind that process name. Does anyone know if that is the case? Any sources to confirm?
- Is there any way to dig deeper into "System_Server" to find the ACTUAL process/service/app/hardware that is causing all these wakelocks? I've also tried GSam Battery Monitor (thanks to - this post) and WLD (Wake Lock Detector) but the most specific any of them get is just "System_Server", even when I chase all the other Process IDs.
- Does anyone have any idea what Time_Daemon does?
. As such, I have Titanium Frozen / Greenified anything I know I don't need, and I keep the 4G / WiFi disabled (with no auto-enablers) and only enable them manually when I intend to use them. I have no syncing, no pushing, no pulling, no updating widgets, no Facebook, etc. With the final point being, short of an errant wakelock, I think most of my drain is from the cell radio haha.
