Root Unimessagingbin.apk Help
KushxCloudsz
I Deleted my Unimessagingbin.apk & Unimessagingbin.odex because my messages were acting up and not sending, after i rebooted my phone, re downladed the apk&odex files put them in system/app folder thinking that would fix it but nope now i cant find my messaging app. And my phone wont let me go home by pressing the button. It was working fine till i deleted the apk&odex n rebooted my phone. Can anyone help me out with this issue? :confused:
By deleting the unimessagebin.apk&odex deleted the airplane mode on the power off thing.
Did you change the permissions to rw-r-r after putting them back?
Yeah i did it with file manager it was weird my home button wasnt working the airplane mode in the power off menu was gone , all it said was "power off" &Restart . I did a factory data reset it erased everything , igot my messaging app back & the power menu fixed. Everytime i posted the apk&odex in the system/app folder it would post but nothing would happen i even rebooted it. Only thing that worked was the factory data reset.
I don't know.. A word of advise though, install recovery for a locked bootloader and make a backup before you tinker with anything. Im so glad I'm done with that phone...
Thanks for the advice man, i can't wait to upgrade. What phone would you say would be the best to upgrade to that isnt $1000? Hows the G2 its Lg also right?:D
