Help Uninstall/disable TTS
Recently I installed google map's text to speech feature. Now the navigation function is really annoying, reading to me the street names in robot-speak. Is there anyways to uninstall this?
You should be able to uninstall it by going to the market page and selecting the uninstall link.
Or you could just turn down the volume in Navigation so you don't have to listen to it.
I tried that. It was an option that always popped up whenever I used Navigation. But the update does not show up when I scroll through marketplace or applications. Maybe I'm stuck with my choice now haha.
Thanks though
Thanks though
Go To Settings Then Accesibility Then Uncheck The TalkBack
Then Your Free To Do Everything With Your CellPhone Without That Annyoying Text To Speech Shit
Wow I am having the same problem with mine. I cannot scroll down to the Accesibility because the TTB is on and won't allow scrolling. I just keeps telling me the last thing I touched..
