Uninstaller for Android tablet
bluenite
Uninstall programs on a tablet with Android 4.3 (Asus MemoPad FHD10 ME302C) is pretty confusing for pc user. After trying more gps navigation with offline maps with sizes of hundreds of mb these remain still in the store. If access for manual removal was clear, so I don't ask here. However, they are often extra data for applications tucked under ten levels=hard-to-find. And I don't know if I remove everything. Some cleaner would not help trace the connection of these data with programs? Nice CleanMaster it cannot too.
thanks for the tip
Peter
If you've already uninstalled the app and there is a large amount of data still on your device, it's probably the offline maps.
Let's say I installed MapFactor from the play store. It will create a folder called /sdcard/.mapfactor/ to store the maps. The leading dot means it's a hidden folder, so you might have to enable "show hidden files" to find it. Delete that folder and you'll have removed everything. No, if you made any customized settings and might want to reinstall the app later, this will delete them as well.
