uninstaller for android
dhongdhong
What is the best uninstaller for android so that no left over files after uninstall.
For example, In windows you have Your Uninstaller. This is an excellent uninstaller which uninstall apps without any left over files .
Similarly is there any such apps for Android ?
Welcome to AF! :)
Via the apps menu you're uninstalling apps from, if you clear the data and cache before you uninstall, it should remove all traces of the app.
There are some apps here: Uninstallers, I've never used them so can't comment on how effective they are.
Welcome to AF! :)
Thanks. You are very much helpful.
I guess I need to follow these steps ...
Settings ---->Application----->Manage Application ---->select Application to uninstall ---->clear data + clear cache ---->click uninstall.
I hope , I'm correct . Could you please confirm if I am in the right track.
