Help Uninstalling music hub 3
As per the title, how do I uninstall music hub 3?
Galaxy s3 android 4.0.4 within settings, application manager, there is no option. I have disabled it but cannot seem to uninstall it.
I recall I downloaded it from Samsung app store on the day I got the SGS3.
I cannot seem to find a short cut icon to run it and besides I'm happy with Poweramp and ProPlayer so just want rid of it.
What is root and where can I get it? Will using root void warranty on sgs3?
I ask as I assume root is a file manager app that allows you to alter delete etc system files?
Root grants you super user access, allowing you to do things like remove apps, backup app data and is generally the first step in installing custom firmware. Fore more info see here: http://androidforums.com/faqs/443432-what-root-being-rooted-mean.html
I'm very pro root, but I wouldn't recommend doing it just because you want to uninstall one app.
It generally also voids your warranty although I've had rooted devices repaired/replaced in the past. Manufacturers will normally tell you they won't repair (or they'll charge for repair), but it all depends on what the tech who receives your device does when they get it back though.
Do you want this moved to the SGS3 forum, the guys there will be the in best position to assist? If root isn't your thing, they may be able to assist with uninstalling the app.
I think it would be best to find another method to remove the app, so if this thread could be moved to a more relevant section for people to advise that would be great.
As for root, i will look into as something to do in a years time.
Thanks for your help.
It came stock on my phone, I'm pretty sure you can't uninstall it without root. My recommendation is to live with just disabling it.
