Uninstalling Problems
JennFlGirl
I can't seem to be able to uninstall some apps, like Books, MyExtras, etc. My phone keeps telling me it's low on storage space, so I click it & it won't let me uninstall i can only clear data
Hi JennFlGirl, and welcome to AF :)
If these are pre-installed apps then you won't be able to uninstall them (or not without "rooting", basically gaining administrator access, which will usually void your warranty). On the plus side, system apps live in a different storage partition, so it's mainly their data that use space, and you can clear the data.
If you visit your device's forum here, or the Android Lounge, you'll find advice on what you can do to help with storage problems.
Glad to have you join us :)
