Universal TV Remote Control
UNIVERSAL TV REMOTE CONTROL.
Universal TV Remote control is an amazing mobile application that is developed for Smart TV users and IR blaster compatible TV set users to control their TV sets from a mobile phone. With over 35 million users in 100 countries, Universal TV remote App is moving ahead as a top choice in the world.
Problems Arising Out of Using Normal TV Remote Control.
Think for a minute, do you face a problem like losing your remote when it’s the time of your favorite show/serial? Does your TV remote battery stop working at wrong hours? Do you smack your little sibling for breaking the remote? Or do Biting and/or boiling your batteries in the water hoping it would result in magically recharging them, etc. ??????????
Universal TV Remote Control- A Solution !!!!!!
Codematics Inc. is here to provide you a solution for your everyday remote control issues. We are presenting you “The No.1 Universal TV Remote Control App” that is successfully running in more than 100 countries with over 35 million users from across the world. Isn’t it amazing that you get a solution for controlling your TV sets in the form of “Universal TV Remote Control” ??????????
Working of Universal TV Remote Control.
The best feature of Universal TV remote control app is that it is workable for both simple TV and Smart-TV users.
If you have simple TV and your mobile device is ir blaster compatible, then you are good to go with this App. The infrared sensor in your cell phone will send infrared rays to the ir of your TV set and will make you enjoy this App to control your TV set.
Further, for Smart TV users, the TV set and phone must be connected with same Wi-Fi device to make your Universal TV remote control app work best for you. It is one of the best options for the users of Smart TV sets including;
–> Apple TV
–> Android TV
–> Google Chromecast
–> Roku
–> LG Smart TV
Best Features of Universal TV Remote Control.
Some of the best features of Universal TV remote control app are:
• It is workable for both simple TV and Smart-TV users.
• You can Download Universal TV remote control App absolutely FREE.
• It’s easy to use and match your expectations.
• New brands and models are constantly added to the already existing long list of TV Brands.
• You can easily view your Gallery Pics and Videos from your mobile on your TV.
Customer Support Service of Universal TV Remote Control App.
Codematics Inc. provides cordial Customer Support to assist users of “Universal TV control App” in instant and best way possible. The Codematics team is working constantlto include maximum TV brands and functionalities in the App. This smart remote control app is being updated accordingly.
If your brand is not listed or the TV remote application is not working with your television, please drop us an email with your TV brand and remote model. We will work on it to make this application compatible with your TV brand.
Get The Universal TV Remote App and enjoy using it. Also, share your valuable feedback with us.
Email Us:
You can contact us at any time. Our customer support will reply you within a very very short period of time.
contact.codematics@gmail.com
support@codematics.co
Always Be Happy and Enjoy Your Life
CodeMatics Inc.
Download it Now:
--> Go to "Google Play Store."
--> Type a word "CodeMatics" in the Search Area.
--> Go for the " Universal TV Remote Control. "
--> Click on the " Install Now " Button.
This app basically supports two different functionalities:
1.) IR functionality: Requires a mobile device with a built-in infrared feature for transmitting remote signals to a TV set.
2.) WiFi functionality: Requires your TV set to support smart functionalities and be connected to the same WiFi network with which your mobile device is connected.
So if you have a Smart TV and that is available in this app, then the app should work for you. Kindly send us your smartTV model number as well as mobile model number, we will try our very best to make it work for you.
Mobile Devices with IR capability:
Samsung:
Samsung Galaxy S6 / S6 Edge / S5 / S5 Active / S5 Mini / S5 Duos / S4 / S4 Active / S4 Mini / S4 Zoom
Galaxy Note 4 / Note 3 / Note Edge / Note 8.0 / Note 10.1 / Note Pro
Galaxy Tab 4 / Tab 3 / Tab 2 / Tab Pro / Tab S / Tab 7.0 Plus / Galaxy J / Galaxy Mega
HTC:
HTC One M9+ / M9 / M8 / M7 / HTC One Max / HTC One Dual Sim / HTC Butterfly 2 / Butterfly S / HTC Desire 600 / Desire 200
Xiaomi:
Xiaomi Mi 5 / 5s / 5s Plus / Mi 4 / 4c / Mi Max / Redmi Note 4 / 3 / 2 / Redmi 3 / 3 Pro / 3s / 3s Prime
There are some LG phones also that supports the IR feature but we have received some mixed response from users using LG phone about the functionality of this app so we do not recommend it.
Also Samsung removed the IR feature from Galaxy S7 release but are now considering to make it available again in the new Galaxy S8 flagship device.
Regards.
Smart TV (WiFi-Enabled) Version of the Universal TV Remote Control.​
We feel glad to inform you that we have enhanced the capability of our app "Universal TV Remote Control." This app now supports multiple TV Set either by Infrared (IR) or WiFi (Smart TV).
In the Ist Phase we have included the following Smart Devices.
1.) LG Smart TVs.
2.) Android TVS.
3.) Google Chromecast.
4.) Roku.
5.) Apple TVs.
This app is capable of performing the following smart functionalities.
-> Easy Mouse & Keyboard Navigation.
-> Share your Media Files.
-> Switch On.
-> Volume Up / Down.
-> Mute / Un-Mute.
-> Channel Up / Down.
-> Media Controls.
How to Use:
Follow this Video link:
Join our Google Plus Community for updates.
https://plus.google.com/u/0/communities/104413505557099530470
Feel free to contact us anytime for any queries at.
You can also visit us at:
www.codematics.co
Always be Happy & Enjoy Your Life.
Regards,
Team CodeMatics
CodeMatics Media Solutions.
