Hello msshanbhag. Welcome to Android Forums. I'm sorry you are having problems with your phone. Here is a link to the Desire area. It's there that you will find the best support for your phone. Good luck to you and thanks for using these forums. Here is a link to the HTC Desire area: HTC Desire - Android Forums
There are several things that could have caused this pop-up error message code 110). There are also a few troubleshooting steps that you can try to eradicate this vexatious problem.
Option 1. Uninstall and reinstall the Google Play store.
Option 2. Remove and reinsert the battery if it ever happens again.
Option 3. Clear cache, data, history, cookie from the web browser. (On any webpage tap menu - more - settings and scroll down to the above-mentioned.
