Shonan
hey guys,
with the unknown wifi network icon notification, when you scroll it down and and click on it can anyone tell if it should do anything, cos mine doesnt it jus highlites that you hav clicked it and then the draw closes, if i want to see wot wifi networks are avaliable i hav to go the long way to it,
i thought for some reason that if you clicked the icon in the notification menu it took you straight there,
i mite be wrong ?
i mite be wrong ?
