unlock procedure
  • Start date Start date
A
Android Question
Guest
I am travelling out side US how can I unlock my Samsang Gallaxy III anroid?
Hi
If you want to carrier unlock it so that you can use a sim from another carrier you should ask your existing carrier for the code and procedure. If you want to roam using your existing carrier on other carriers networks you probably don't need to do anything but check with your carrier that it will work where you are going.
Roger
