Unlock Studder
Joe Eris
Every time I unlock, I see like a split second studder with my wallpaper. It will quickly flash to the left portion of my wallpaper, and then center itself. This is so annoying. Has anyone else experienced this? If so do you know how to fix it? Any help would be much appreciated. Thanks (unsuccessful fixes that I've tried.... Using different size /resolution wallpaper, turning off window scale animation and transition animation, turning off lock screen animation, adding/subtracting screens. Oh yeah and I'm using Go Launcher.
Ok thanks. Yeah, after trying a few different launchers I discovered that it definitely is Go Launcher that is causing the problem.
TouchWiz is solid as a rock. Why change?
I enjoy all the different screen transitions , and the ability to swipe up and hide/show the notification bar, and being able to hide the dock.
