Hi all,
I was wondering, is it possible to unlock a phone by rooting and flashing a custom ROM on it?
By "unlocking", I am referring to phones that are only possible to be used by one carrier for instance AT&T.
any info appreciated.
Also,some carrier branded phones are more developer friendly than others.
So,if you're specifically referring to custom ROMs,ensure that it is intended for that specific model & carrier,regardless if it has been SIM Unlocked or not,as
@psionandy mentioned,the two unlocks are different beasts altogether,one has nothing to do with the other.
If you need to SIM Unlock a phone,contact the carrier it was originally tied to,all carriers have slightly different requirements,but,most basically require that any contractual obligations be met before doing so,with a few notable exceptions (Military personnel stationed overseas/out of country/etc).....
There are SIM Unlocking services available for a fee,GOOGLE is your friend.
However,even if you go this route,if there are contractual obligations that are still pending/unfulfilled,the device is likely blacklisted,meaning almost no one will activate it on their network.
