Root Unmount/Mount SD card
Ok so i updated to the newst 1.6 from BH_man's release. When everything looked good i tried gallary, but it kept FCing on me. When i looked around and found out that i had to make a new folder called sd on the card. So after doing that it would stay at the Loading screen. I could Back button out of it but then it would say i have no pictures. Then for some reason i decided to reformat the card. Bad move. After i went to setting >unmount> then format, i cant get it to mount the card again! I dunno what to do :(
Reboot the Phone...
I did do that it :(
I restarted the phone. Nothing
I took out the Card and put it back in nothing.
I reformatted the card using my computer while its in the phone Nothing.
I did do that it :(
Um? Sounds Like the Card... You have the MicroSD to SD adapter that the phone came with.... If so, then Format on the Computer.. Must be a Fat 16 / 32... Will not Read the Card if you format to NTFS windows partition.
Also, it's a Bad thing to Format the Card while in the Phone....
Meh i justed switched to another card and it said "Preparing SD Card" or somthing now it works fine. Thanks for the quick response BH_man. <3
