whoshotjr2006
READ EVERYTHING BEFORE YOU CONTINUE ANY FURTHER!!!! DEV INFO IS IN 2ND POST.
NEWS:
Build updated. This one now has double tap to wake and uses bad_mofo's cm12.1 caf kernel which also brings us overclocked processor, fast charge, etc. Should be an all around smoother experience.
CHANGELOG:
061015: Downloaded source and modified device tree to build. Everything seems to work as well as cm11.
061315: fixed double tap to wake, added Bad_MOFO_33's cm12.1 caf kernel
DISCLAIMER:
i do not force you to flash these roms. what you do is on you. ill try to help you, but do not blame me for anything, especially if something goes wrong. you know the risk, and if you dont know or understand something, then dont flash this rom.
TAKE A GOOD BACKUP WITH TWRP BEFORE FLASHING!
RECOMMENDED RECOVERY:
TWRP lollipop link:
http://androidforums.com/threads/recovery-twrp-2-8-5-0-lollipop.902943/
Working:
Anything that is not listed below
half working:
Green tint on back camera on some volts
NFC needs some fixup, waiting for logcats
Youtube: Open settings in video, disable HQ video stream for now. This also means apps that rely on h264 decoding will not work properly for now. (Netflix) Also could explain broken camcorder. (possibly)
Camcorder: Use Camu or something like it from google play store
Boot animation not working on first boot, but first boot time is stupid fast
not working:
ir blaster
you tell me
NOTE: Get a gps lock in stock rom or whichever rom you had before with working gps before you flash this. This is a quirk with many qcom based phones, if you dont get a lock before you flash this your gps probably wont work.
Flash the rom, then the gapps package of your choice (kitkat gapps) and then flash either the Virgin or Boost apn fix below.
Thanks to Mopedryder for both:
Virgin APN Fix:
http://androidforums.com/threads/mo...apn-fix-wip-cm-aosp-4-4-x.840298/#post6516416
Boost APN Fix:
http://androidforums.com/threads/mod-universal-boost-apn-fix-for-d2lte-builds-mod.840501/
Rom Download Link:
https://www.androidfilehost.com/?fid=24052804347759262
NEWS:
CHANGELOG:
DISCLAIMER:
TWRP lollipop link:
Working:
half working:
not working:
ir blaster
you tell me
Virgin APN Fix:
Boost APN Fix:
Rom Download Link:
