Root Unofficial CyanogenMod 11 for LG L70 D320 D320n D325
How best to make the SD card in CM11:
  • Total voters
    110
  • Poll closed .
Work fine on lg d325. Cm11 internal sd version. But when i go to app manage. There is no the button for move to sd card. Why? It can be insifficient storage..
Perhaps this isn't the best thread to ask for help but......
I'm currently running cm11 on my LG. Occasionally the phone will not have service. When this first occurred it last about 2 hours.
It happened again last night and I haven't regained any service even after rebooting.
Any suggestions on how to remedy this issue?
This doesn't sound like a typical cm problem... You sure it's not your service?
My brother still gets service in my house but I do not. I gonna go to Metro in a bit to check out the issue.
I'll reflash my phone to see if that fixes the issues
So I didn't flash my phone but my service came back after being going for about a day so..... I'm getting it's my service or I damaged my phone physically.
Thank you for the input however!
when I try go to download mode or factory reset, my device showing purple screen.
DBI Err Fatal!
DemiGod Crash Handler : DBI Err Fatal!
Board Rev.:1.0
Ram dump mode.
Option : SD card ram dump mode.
Push below files to sdcard before test.
rdcookie.txt, rtcookie.txt
Please do folliwing action.
1) Ram dump Mode. Please connect USB.
2) Get the ram dump image using QPST Configuration.
3) If sdcard ram dump enabled just wait for reboot.
4) Collect ramdump files from your pc or sdcard.
5) Send e-mail to W5-BSP-Global@lge.com
if i try turn on again then my device stuck in LG logos and can't go anywhere.
I try many tutorial but it doesn't work.
what should I do ? :(
DBI Err Fatal!
Board Rev.:1.0
Ram dump mode.
WARNING! SUCCESS WILL RESULT IN A TOTAL WIPE OF THE PHONE! Failure will leave you in this state.
YOU HAVE BEEN WARNED!
Please tell me te model of the phone if you understand and you want to continue. (D320n is mine.)
(Answer includes LG Flash Tool)
This is a good looking ROM....
But after flash, the battery was drain almost at 80% since 6:00 am to 1:00 pm
not sure if someone else had the same problem?
LG L70 MS323
Are you on the external sd version? I go through the same thing, I'm on the no internal sd version. If you use the internal sd version, I hear battery life is much better
