Root Unofficial CyanogenMod 12.1 for LG L40 D170
Hi, i'm new in the forums, and i would like to ask if there is a possibility to import the ROM to Lg L40 D175F device..
Thanks anyway ^^
I cant find the "Sign in to Google Account" option in the Accounts section, theres only IMAP,Exchange,POP3 and CyanogenMod Acc and i cant open play store and restore my apps. Is it supposed to be like that or am I doing something wrong here? ._.
i fixed it already, kinda odd how the gapps dont show up even after i flash them. Had to download and install GPS to sign in to Google
no nothing change
cm before installing said its f2fs and its going to format it to ext4 and after that go for installing cm
I see, thanks for the quick reply!
Could you also give me some brief instruction as how you converted to f2fs and installed CM12.1? I'd really appreciate it
Edit: I formatted system/ , cache/ and data/ partitions to f2fs and when i installed cm12.1 the system partition goes back to ext4 so now only data and cache partitions are f2fs. After proceeding with flashing gapps, the phone kinda gets stuck at the bootanimation, any solutions?
The system partitions still revert to ext4 D:
And changing cache and data partitions to f2fs doesnt work.(Both partitions are successfully converted to f2fs but shows 0mb space even after reboot to recovery/refreshing recovery )
anyone know the proper steps to convert cache and data partitions to f2fs?
(Phone gets stuck in bootanimation after converting those partitions to f2fs and recovery shows 0mb for the partitions)
Please can you fix the gpio-layout keys for d160? In cyanogenmod 11 they worked perfectly
привет друг, как это было, чтобы установить его на D160 я работал хорошо? пожалуйста, если не много хлопот indequeme спасибо. Вы также можете по электронной почте
***mod redacted***
hola amigo, como hizo para instalarlo en su d160 le funciono bien? por favor si no es mucha molestia indequeme gracias. puedes enviarme un correo tambien ***mod redacted***
hello friend, as it did to install it on your d160 I worked well? please if not a lot of hassle indequeme thanks. You also can email***mod redacted***
Olá amigo, como fez para instalá-lo em seu d160 eu trabalhei bem? por favor, se não um monte de problemas indequeme obrigado. Você também pode enviar e-mail***mod redacted***
***mod note - please use our messaging system to contact the poster. posting email addresses publicly will be scraped by spambots and result in inboxes full of junk mail
Email address removed. @amendoza9, feel free to provide your address via Private Messaging if necessary. Publicly posting it attracts spambots.;)
Oh, that's one heck of an effort to make sure someone can read your request.:D:thumbsupdroid:
for guys that have performance problem on l40 model do this:
on build.prop file that you have to pull it by adb, edit dalvik.vm.heaptargetutilization=0.75 to dalvik.vm.heaptargetutilization=0.25 and reboot into recovery and wipe dalvik and cache. and after all reboot to system. now you have to wait for optimizing android apps another time. Enjoy
The LMnTRiX
Will be added to next update.
2015-08-22
  • Add F2FS support for /data and /cache
  • Fixed offline mode chargercharger
dalvik.vm.heaptargetutilization added, but not changed, used default. Will look on it latter.
hello and I managed to install CM12 on the d160 a sim but has a problem option buttons home does not work that ago to work ay to know to install the ROM on the d180 have to install the KDZ the d170 dual sim if you help me I would appreciate it
si se puede cambiar el ahy KDZ que tengo la d160 pero no puede obtener derecho a los botones de la cm12.1 CM12 o CM11 en pero si estos no tienen que utilizar para activar la barra de navegación CM12
