antonioblee1
Clear cache in recovery and try again ...flash worksOn ms323 camera fixed.
On my ms323 torch and flash worked. @LitrosNub and another ms323 owners, how on your devices?
flash smaller gapps. that means there's not enough space for gapps in /system. use nano or pico.so I just flashed my ms323, but when I tried to flash gapps, I got an error code: 70. how do I fix that?
Sorry, my english is bad. The right is "clicked". Help me about calendar app.You typed ”licked” instead of ”clicked”.
nope, only ms323. you could buy and send @vm03 and D320F8 for him to fix the camera problem, that's how he fixed the ms323 camera.Rear Camera on D320f8???
Have you tried installing Google Calendar?Sorry, my english is bad. The right is "clicked". Help me about calendar app.
Only cm12.1, may by later backport to cm11.Does the camera fix work on cm12, or only on 12.1?
And few of upstream updates.So build may 10 is only ms323 camera fix, I don't need to upgrade, right?
Read first post.I recently installed cm12.1 on ms323 and when I tap on "security" it says "unfortunately, settings has stopped working". I can access all other settings appropriately. Please help.
Ms323 led is flashing? Even on flashlight led is blinking?Only cm12.1, may by later backport to cm11.
Read first post.
Key combo or enable reboot menu options in developer settings.Thanks @vm03 by the way, if anyone can't boot in recovery after flashing, you can also doing on PC via adb.
Have you enought free memory in your device?Does anyone else have issues with Netflix? I can log in fine, but when trying to play a video, it gets stuck on the loading screen and nothing else happens.
I have a ms323 with the 5/10/15 build of CM 12.1. I've tried the latest version of Netflix, as well as older apks and it's the same issue. I've also tried going back to old CM 12 (4/18/15 build) and same.
