Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
what commands did you wrote?
Did the terminal emulator:
cd /system
su
sh net.sh
(get "no such file or directory")
And I enabled data while turned off WiFi...
And placed the net.su in the system directory...
Tried script managers as well?
(get "no such file or directory" or some "unexpected fi" error)
Thanks in advance ☺
cd /system
su
sh net.sh
Thanks in advance ☺
try su and then cd /system...
After i extended my storage on sdcard sometimes when i boot and input sim pin it loads really long (idk how much because i pull out battery and when it boots againg i type pin and it unlocks in second... also it says 7.84 gb free and it is saying that its running out of space and when i try to send viber voice message i cant because of that...
Bluetooth audio working now :).
Can someone help me with the net.sh script?
cd /storage/emulated/legacy
su
cp net.sh /system
EDIT: I moved it in /system with Root Explorer, but I still get synthax error: 'fi' unexpected
Fix for mobile data on LG L70
1. Download the SH File: http://d-h.st/dPZk. Then, put it in /system and change its permissions to 744.
2. Download SManager, on first run, give it superuser permissions. Find the file in /system and tap on it. Then, click su and net (see screenshot).
3. Disable WiFi, enable data and click run.
Yes. Just install zip in recovery. From cm12 to new cm12 of course.
Wait... If I already have cm-12-20150106, I don't have to wipe everything to install cm-12-20150110 ? And there will be no bugs and no way to brick something ?
Update: after flash the last version of (2015-01-10) all now work at the best! Buttons also, camera, and networs, all work! Great work vm03, thank you! :)
Use this script!
See screenshots.
1. Download the SH File: http://d-h.st/dPZk. Then, put it in /system/ and change its permissions to 777.
2. Download SManager and find the file in /system/ and tap on it. Then, click su and net.
It must work.
Thaaank yooouuu!
It wooorks, yooohoooh ☺☺☺
And thank you everyone for your efforts
Internet working with script :) Thank you, guys!
Can I somehow help you try to fix data/NFC? Could I provide some files or logs? D320n here
Status
