ledosladoledi
moved all apps to sdcard and i have 650 mb free. Its running very smoothly, will see about battery...
EDIT:
camera works great and torch too!
EDIT:
Can we somehow help?Still, I can't do it without device...
Find why nfc not working...Can we somehow help?
Maybe not work. In d325 RIL fully not working and i can't check itDoes data work on d320n, or is it just me? I can't get it to work, all I get is exclamation mark on network icon...
It doesn't... Most probably solution is the same like one for msm323 (that script thing).Maybe not work. In d325 RIL fully not working and i can't check it
well... i can give you log when i try to enable NFC if that helps?Find why nfc not working...![]()
testing out cm12 on my LG l70 ms323 , excited.![]()
Can you let me know if everything is working. Mainly data, please.
Alright guys so everything works pretty good on the ms323. Buttons work except quick button has no use. You can make calls and texts. Sadly data does not work :/. Tried pulling up google, does not work. great romLet me know as well.![]()
And you did not have to mod the CM12 at all to get buttons or RIL (call/text) working???Alright guys so everything works pretty good on the ms323. Buttons work except quick button has no use. You can make calls and texts. Sadly data does not work :/. Tried pulling up google, does not work. great rom
not at allAnd you did not have to mod the CM12 at all to get buttons or RIL (call/text) working???![]()
worked perfectly just the quick button has no use that is all hopefully that can changeDoes Link2SD work???;( only the front camera works
Does the script work on this version? Didn't when I used it but just wanted to check. And Link2SD?Yes u still need the script for data. Still front facing camera only on ms323. But overall the ROM is great.
yesDoes Link2SD work???
how can i test it to make sure? i have moved a couple apps to my sd cardAlright guys so everything works pretty good on the ms323. Buttons work except quick button has no use. You can make calls and texts. Sadly data does not work :/. Tried pulling up google, does not work. great rom
not at allworked perfectly just the quick button has no use that is all hopefully that can change
