M
Member1771050
Guest
Wipe dalvik cache and cache, I had your problem ONCE, and that helped me.Yea but i need to reboot it every 20 minI need to find a fix for this!
I wiped everything....lets go to PM we spam alotWipe dalvik cache and cache, I had your problem ONCE, and that helped me.
I think it may be a "heating" issue. The phone says ALL THE TIME with apps and such that it needs to cool down... Like the wrong temp has been set for it to cool down to...Yea but i need to reboot it every 20 minI need to find a fix for this!
Can this be a group PM so I can readz?I wiped everything....lets go to PM we spam alot
EDIT: Can you PM me zlaja? I can't PM you :O
Anybody can send me boot.img and dmesg (after boot) from MS323 stock?
All the same. And run camera before save dmesg.
If I was you I wouldn't flash it... Idk why but I think think its a bad idea...Hi. I have an LG L65( D280f) which apparently has the same motherboard and casing as the L70 sans Gorilla glass and smaller screen. As shown in this picture of mine: http://imgur.com/o1l8WI8
Could this one work on it, provided it's already got an unlocked bootloader with TWRP?
You can hardbrick your device. Once is device hardbricked, you can't make unbrick.What could potentially happen? In case it doesn't work, ¿ could I reinstall the original OS with previously made backups ?
Reboot phone, after boot complete, open camera and exit. Open terminal or adb shell and runHome now. What do I do to get you the dmesg? Lastly, do I need to take a picture from front and/or back camera?
L65 has different hardware. At least screen. On 4pda.ru you can find unlocked bootloader and partialy working cwm.Hi. I have an LG L65( D280f) which apparently has the same motherboard and casing as the L70 sans Gorilla glass and smaller screen. As shown in this picture of mine: http://imgur.com/o1l8WI8
Sure, just inv me cuz i don't know how. I'm still a noob on the forumsCan this be a group PM so I can readz?
shouldn't he do that command and then open camera?Reboot phone, after boot complete, open camera and exit. Open terminal or adb shell and run
su
dmesg > /storage/sdcard1/dmesg.txt
Send dmesg.txt to me.
No, dmesg showing what has been.shouldn't he do that command and then open camera?
DamnNo, dmesg showing what has been.
ummm... now i am even more sure that i done something wrong with dmesg and logcat when i was testing nfc...No, dmesg showing what has been.
I remember everything was ok.ummm... now i am even more sure that i done something wrong with dmesg and logcat when i was testing nfc...
What kind of issue do you think it is if not showing in dmesg still blobs?I remember everything was ok.![]()
did you saw that dmsg and logcat i sent u in pm?I remember everything was ok.![]()
Sorry, understand...What kind of issue do you think it is if not showing in dmesg still blobs?
About NFC, yes. But no new info in this logs.did you saw that dmsg and logcat i sent u in pm?
that was a long time ago...About NFC, yes. But no new info in this logs.
