Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
I get alittle worked up from "are you gonna fix this bug" questions. Especially with the, "i want it fixed real bad. I dont like gross bugs and I'm not gonna try until I know you fixed it" sorry for the rant.
Hi Friends,
After upgrading my device MS323 to lollipop, I install mounts2SD on my device and I don't now how mounts2sd app ruined my device. Now I am able to see only blank screen and able to connect only via adb(not able to connect via fastboot). Can you please tell em how to recover my device back.
Note: I don't have any recovery image on my device so I can't go to recovery option.
Ooo so you tryed the download mode/ fastboot boot method yes? If you have adb try looking up l70 laf multitool if you haven't already. It has the command to put a cwm recovery img on your phone. Or make it quicker
If you put the recovery IMG on the root of your external_sd. Do
adb shell
su
did if=/storage/external_SD/recovery.img of=/dev/block/platform/msm_sdcc.1/by-name/laf
Before doing this command let me express to you, if you want to boot be able to cold boot into recovery you must place a recovery.IMG on your laf partition. You will do the fastboot boot method key press combo+ USBcable
(Before you dd but after you adb shell. Use
ls
If in shell it should give you the paths like /system, /sdcard, /storage, /dev, so you can be sure the path to your sdcard.
I edited the original lglafmultitool to do exactly this easier. It flashes phillz recovery to your laf. I left the orignal tool in there, labeled Run the hiRun batch file is the one I edited. I edited this tool for personal use, I did not make anything but the additions I mentioned but maybe it can help
Edit:IF ANYONE CAN HELP THIS GUY WITH AN EASIER METHOD FEEL FREE TO. :)
...I hate uploading file directly from mobile.. -_-
Hi Friends,
sry sry sry had to hop on PC. still . .. ... . .. ... waiting for upload! ima send the link to mega.co
heres what to do
adb push phil.img /sdcard/
adb shell
su
dd if=/sdcard/phil.img of=/dev/block/platform/msm_sdcc.1/by-name/laf
and heres phil.img
V
it wont let me upload anything so use that adb command but edit phil.img and input the one you download
Thanks a lot,
Now its is working :)
adb shell
su
ls
adb shell
su
ls
Hi,
after I upgraded from stock to cm-12-20150131-UNOFFICIAL-w5.zip, I cannot connect 3G data, exclamation mark is shown on signal icon.
Is the non-working data a known issue, or how can I fix it?
It's on D320n.
Thanks.
Have you made a complete factory reset before installing that could me the problem.
also if you get any error messages please reply them to me or any developer etc. zlaja84
Try that and try again
Im try again now. But again stuck on :
--Installing : /external_sd/cm-12-20150131- UNOFFICIAL-w5.zip
Finding update package . . .
Opening update package . . .
Installing update . . .
detected filesystem ext4 for dev/block/platform/msm_sdcc.1/by-name/system
did you maybe extended your storage to sd card? And did you wiped system, data, cache...?
man if cheat my cell phone tell for him that is a d320 i enable my calls ? or just enable my sim card put the d320's aboot ?
the fun you just said?? sorry i dont understand :/ i think that u are trying to say that u have d325 and u want to make it device register itself as D320??
Fix for mobile data on LG L70
1. Download the SH File: http://d-h.st/dPZk. Then, put it in /system and change its permissions to 744.
2. Download SManager, on first run, give it superuser permissions. Find the file in /system and tap on it. Then, click su and net (see screenshot).
3. Disable WiFi, enable data and click run.
your solution worked me in the right way, and I have internet mobile network, thank you very much.
my phone is a d320f8
Hi,
after trying for one day, I found that when someone calls me, or I call someone, it hangs up after 30-90secs.
I don't see mention about this, someone has an idea where to start finding the culprit?
For now I'm back at stock fw, but since I'm getting expert at up/down-grading, I can give a try again...
Thanks
Im finally install.
But i have one more question.
Do anyone know how to make this white background in menu to transparent or something like that ?
Status
