karib
I am getting a fascinate next week, so I thought I should unpartition my sd card in preparation for the new phone. I followed the directions listed here:
The Amon_RA recovery ("Wipe" sub-menu) entry "Wipe SD:ext partition" only deletes the files that are there - it does not change the partitioning of the card.
If you want to un-partition the card, use the "Partition sdcard" menu, and select "Partition SD".
When it asks you for the size of the swap and ext partitions, enter a value of zero for both; it will then re-partition the entire card as VFAT/FAT32.
Note for the OP: Back your entire SD card up to the PC before you start! Re-partitioning destroys everything on the SD card
eu1
I then did a system reboot. Now most apps are gone and most importantly things like the Market say that "the linked program is no longer installed on your phone". I have no idea what I did wrong! I do have titanium backup, but I don't know how to restore anything with it because its not showing up anywhere on my phone and I can't get into the market to reinstall it. I did make a copy of my sd card before unpartitioning it and then reloaded it. Can someone please help a girl out here??
eu1
